I made the floorpan ready today. I'll put it on the car tomorrow. I used 2 small pieces of corroplast and cur out room for the tire. Then i put it up so i could draw the line of the bumper on it. Also i made it long enough so i can put the pan against the transmisson. When i had the line of the bumper on i took the line out about 5cm to create a splitter. And afther cutting the first half i just copied it. And put them together with ducktape. Also i took a small pice of coroplast and taped it over the cap to make it a little more stable. Then i took the L piece and cut it to length and made a halve cut in the middle so i could bend it. Afther i was ready and happy with the shape and placement i taped it onto the plates. And put the leftover L piece on the back end if the plate. Then i drilled holes to put in the bolts. Afther tightening the bolts i taped everyting up to make it a little neater. I'm happy with the result of the plate. And will put ut on tomorrow.
