Old 12-14-2014, 07:13 AM   #1452 (permalink)
cts_casemod
Originally Posted by e*clipse View Post
Paul:
I was digging through some boxes of stuff I have and found this:
http://www.beisensors.com/pdfs/L25-o...al-encoder.pdf
It's a sooooper high precision (2540 cycles/turn) encoder.
It's got a 1/4" shaft with a flat on it, so it doesn't really meet your motor's requirements, but if we could figure out a way to connect it, it may work.
Does the motor have a shaft out the back?
- E*clipse
Why don't you guys use the flywheel and a reluctance sensor as an encoder? That would cut a significant portion of the costs.
The input capture peripheral and a free running timer can be used to measure the time between each pulse
The Following User Says Thank You to cts_casemod For This Useful Post:
e*clipse (12-14-2014)
