Old 12-14-2014, 11:29 AM   #1454 (permalink)
P-hack
P-hack's Avatar
awesomer - '04 Toyota prius
I took a second to look at heubners code, basically you set fweak to the field weakining frequency, it is also the point where max dynamic range is at (i.e. full svpwm). After that you can only increase frequency without increasing v (and still have a sinewave). so field weakening is constant v with increasing hz. I didn't see anything fancy about slip at that point.
