Old 12-14-2014, 01:09 PM   #1456 (permalink)
cts_casemod
I wrote the formulas for all that and calculated the table below
Parameters are:
Motor nominal Voltage: 208VAC
Motor nominal Frequency: 50Hz
Motor rated Slip: 70RPM
Battery cut out voltage: 320VDC
Notice how having a variable slip, with the aim of keeping rotor power constant above nameplate, can attain a larger output torque. There was a topic on DIY car forums where we discussed this 2 years ago.
The Following 2 Users Say Thank You to cts_casemod For This Useful Post:
e*clipse (12-14-2014), thingstodo (12-14-2014)
