Old 12-14-2014, 05:46 PM   #13 (permalink)
RunningStrong
Panzerwagon - '02 Skoda Fabia
90 day: 53.88 mpg (US)
Having a low Cd does not correlate to an impractical car. The Leaf could be improved a lot with affecting it practicality. Case in point is the Prius; it is more practical than the Leaf. The Model S is also and example of a much larger car that has the same drag as the Prius.
When I referred to practical, I wasn't referring to the drive-train. I was referring to the day-to-day usability like luggage space and cabin space.
The Leaf has more luggage space, sits higher, and is shorter. As a whole, it's a very popular body style in Europe at the moment.
Originally Posted by Hypermiler1995 View Post
Correct me if I'm wrong, but what you are describing is larger frontal area, not cd, you could make a 1/2 scale model of any car, and the cd would be the same, the frontal area would change, and thus the cda would change. Is this correct?
No, I'm not. A low slung saloon generally benefits from a better windscreen rake, rear windscreen rake, and a boot lid. A high-sitting hatchback often has a steeper windscreen and an abrupt tail.
