Originally Posted by fusion210
Mine does that sometimes. Usually I'll shut the car off, turn the key back to on and clear the code. Then for good measure, do the same before I start it up.
It's a 1998 neon.
My 2008 smart gets a code every once in awhile and to clear it you turn off the engine and immediately turn the key back on without starting it and then hit the clear on the scangage, works every time so far.
