Old 12-14-2014, 11:58 PM   #1465 (permalink)
freebeard
To get the absolute angle of the flywheel you would need to provide some sort of index. cts_casemod suggested welding two teeth together to get a longer gap between positive and negative pulses on those teeth. This may be difficult to detect or discriminate from a change in RPM especially at very low RPM.
Not as soon as you engage the starter.
I know, I know. But it's a useful place for an airconditioning pump or a pump for the Coanda nozzles. Assuming you even need a ring gear.
cts_casemod (12-15-2014)
