Old 12-15-2014, 05:15 PM   #1472 (permalink)
e*clipse
Permanent Apprentice
Originally Posted by MPaulHolmes View Post
There is a shaft on back and front. The dang thing sticks out like 1 foot in both directions. haha. 0.875" near the motor, and it gets smaller. I forgot how much smaller. I'll measure it today. Also, way the heck away from the motor (like 8") the shaft has a right angle cut on it, with the other 3/4" of the circumference of a cross section still circular.
Well, it will seem pretty hokey, but probably work. - - The sensor I have is a quadrature sensor with an index pulse. The shaft diameter is 1/4" with a flat machined onto it.
I can make a shaft adapter; would you be able to make some 8" long bracket for the thing? I guess another way to approach it would be a timing belt...
E*clipse
