Old 12-15-2014, 06:30 PM   #36 (permalink)
aerohead
tail/VGs
Originally Posted by Hypermiler1995 View Post
that is why I said to use the mini boattail, a virtual would be too uncontrolled,
might cut down the low pressure area, but would cause turbulence. The yurastyle neo prius has VGs on the mirrors, but there is far less drag area to fill.
Aren't these store-bought VGs? (though they're the only ones i found that seemed to work.)
*Yes,I caught the part about the mini boat tail.And I was trying to emphasize the importance of where the trailing edges terminate to guarantee reattachment WITH the VGs.
*With respect to the VGs,I understand that Mitsubishi designed the units used on the Lancer.
*VGs on mirrors are usually the result wind noise discovered in an acoustic wind tunnel.The VGs can alter the noise signature of the mirror and may not be intended for drag reduction.Again,with a mirror,there would be no structure for separated air to reattach to,just like the semi-trailers.
