Belly pan, rear wheel spats, block heater (convenient hidden plug-in would be the tricky bit though), higher ratio manual steering gear or electric (guessing electric would be a pain unless someone makes a kit to do it) there seems to be enough 3.6 variants out there that coming up with a non p/s belt routing option should be doable
