Old 12-17-2014, 10:24 PM   #59 (permalink)
Hypermiler1995
Suki - '11 Suzuki SX4
Team Suzuki
90 day: 26.26 mpg (US)
Originally Posted by 67-ls1 View Post
Yeah, the more I follow this the more I get concerned about the aero aspect of my project. Looking at it from the front and below, it is anything but smooth. I will add an air dam to the front and try to close up the grill as best I can without cooling problems. I don't think a belly pan is in the cards given everything that is under there, so I will concentrate on keeping as much aid out as I can.
Be sure to add a lip onto the air dam, as it would force air to go off the sides of the air dam and would keep the air from going under, very important if you don't use a belly pan (though I would if I were you).
You can also consider a mirror delete, and maybe some small kamm pieces on the trunk, and maybe the top of the back window, you could try VGs here too (test it though).
"Ignorance is bliss, but only for the ignorant"-Hypermiler1995
The Following User Says Thank You to Hypermiler1995 For This Useful Post:
67-ls1 (12-17-2014)
