Old 12-18-2014, 09:38 PM   #16 (permalink)
Rembrant
Rembrant's Avatar
Originally Posted by PAFirefighter11 View Post
I picked up a t-stat and need to replace it ASAP. I really want to do a grille block, maybe even this Saturday if the weather allows. At least that will get the temps back up.
Make sure you get the plastic t-stat neck and new o-ring as well. I just replaced the t-stat in my 03 TDI, and the two clips in the neck cracked off when I tried to remove it. The plastic neck and o-ring were in-stock at the dealer and only about $10 bucks. Just FYI.
Rem
~You can walk a mile in another man's shoes, but then you're a mile away and you have his shoes~
