Old 12-19-2014, 07:04 PM   #71 (permalink)
aerohead
vented
Originally Posted by 67-ls1 View Post
Yeah, the more I follow this the more I get concerned about the aero aspect of my project. Looking at it from the front and below, it is anything but smooth. I will add an air dam to the front and try to close up the grill as best I can without cooling problems. I don't think a belly pan is in the cards given everything that is under there, so I will concentrate on keeping as much aid out as I can.
Has anyone ever "vented" the under car area?
The big dogs would say don't do it.If anything,build an airtight fence around the perimeter,as low as the bottom of the naughty bits,and let the air pool inside it,upside down.The free stream will skim over this dead air as as if it were a virtual belly pan.(airdam-to-rocker panel extensions, all the way, and a lowered rear valence to match).
