After doing some more research I found the blue/gl also has a taller gear ratio then the other manual models (cant find the exact ratio but its highway mpg is 2 mpg higher then the other manual models aka the same as the automatic) so ill have to keep my eye out for one of those bad boys. The only reason I dont already have a manual is due to the fact I live in a hilly region with lots of streets with wonderful hilltops with stop signs or lights at them (massive roll back even in an auto)
