Old 12-22-2014, 12:01 PM   #1 (permalink)
OG VX
JDM hypeR mileR
OG VX's Avatar
The OG VX - '92 Honda Civic VX
90 day: 68.64 mpg (US)
92-95 VX: Defrost Switch Re-Purposed to become Kill Switch
Hello all, Need some help here.
I want to re-purpose a OEM rear-defrost switch to become a kill switch. Later, I will also add a second kill switch on the shift knob. I want to have BOTH options. The shift knob will have a momentary button, which I will hold down for a length of time. I would also be able to push the OEM defrost button for extended coasts/engine cut-offs.
I'll be relocating the current rear defroster and wiring to the blank spot on the LEFT side of the steering wheel. I don't won't to loose the defrost functionality. But, I want the kill switch to be on the right side, since that's a spot that's easier to get to quickly.
It should also be stated that I am using a second OEM defrost switch with a junkyard pig-tail. I want to run off the OEM wires. Any clue how I can do this? I'll try to get a wiring diagram up here, if I can find one.
I'm not going to lie, some of this is for "show" as well. I'll paint the button green and add a leaf to it. Should be a nice talking point at shows, and another element of "green" on the dash. But I do want it to be functional.
Any input appreciated, thanks!
"Yesterday as I was going in to the shop, I came upon a recently killed Armadillo in the middle of the road with one front leg sticking up. As I passed over him he "High Fived" my air dam. I thought that showed a great attitude on his part." -The Donkey CRX
