Originally Posted by Daox
You'll have to wire the switches in series. The defrost switch will have to be 'on' normally so it doesn't interrupt the signal.
OK, this is concerning, as I believe the defroster switch is on a time of sorts, correct? So, that means after being "on" for a time, it will shut off and randomly cut off power to the injectors, correct? No bueno.
Originally Posted by spacemanspif
I don't understand why you need 2 switches. You say you want one for "long" shut downs but once the engine has been stopped your shut down can be as long as you want; the engine doesn't restart when you let off the momentary kill switch. It's a momentary for that reason, once your finger is off the button, the car is READY for restart whenever you are; and will do so by keying the starter or bump starting the engine.
I see. I'm still learning on all of this. Thanks for the heads up. I guess I'll keep waiting for that new shift knob Doax is building
![Wink](/forum/images/smilies/wink.gif)
