Hmmm, but does it have any effect on the FIRST brake press after the engine starts? In other words, does it take time to evacuate the resevoir to give you boost? So if you have to panic stop just a few seconds after starting off (for example you start through an intersection just as some nut decides to run the light), do you have brake boost?
