Old 12-24-2014, 08:35 PM   #6 (permalink)
freebeard
Well, I'd number the pictures for you if I could. But the one I wanted to point out is the one you used as an example.
By way of your explanation—the discontinuities around the bumpers would be due to lack of sensor data.
Do you think the abstraction where they have the pressure radiating normal to the surface, or the one with a single straight line is less misleading?
