The other day I was thinking about system isolation.
Normally one does away with linking the HV and LV grounds for Isolation purposes, but that got me thinking what would happen if a fault on the motor windings does occur.
The motor is earthed to the chassis, so the chassis will become live. The isolation means a standard RCD cannot be used to detect the fault.
The other thing is capacitive coupling. There may be a difference of potential of a few KV due to static charge accumulation that may blow the isolators or other devices that have linkage between the power rails.
Has anyone considered this?
