Old 12-26-2014, 02:44 PM   #5 (permalink)
kafer65
Tinkerer
kafer65's Avatar
Silver - '15 Mazda CX-5 Sport
Team Mazda
90 day: 37.23 mpg (US)
I'm cutting from the same stainless sheet I used for the mirror fillets on the doors.
The lip has a changing offset depth so I need to make the brackets conform to that depth and hold the skirt mass while vibrating from the firm ride (aired up).
I weighed the first skirt I cut at 1 lb. 13.5 ounces. I think each stainless bracket is strong enough to hold individually, but I'm sure I'll have at least two at the top of the arch maybe more.
One side effect of the mirror delete is that my window won't roll up all the way when I pull a click on the power window switch. It rolls it up and down if I hold the button at least.
Mirror deletes, 80% grill blocks, wheel covers, 50 psi tires = 6% better MPG avg. over a year. Wheel skirts overcoming ethanol winter fuel mpg losses and more!
http://ecomodder.com/forum/showthrea...ead-30641.html
