Old 12-27-2014, 01:39 PM   #1490 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by MPaulHolmes View Post
I was thinking of adding a leakage current monitor circuit, with a known large resistance between pack ground and chassis. And if the resistance drops below a particular value, then it would flag an alarm.
First I guess I should ask how small a current you would be allowing. If it's under 1 mA, then no one should get a shock from it but it may tingle a bit
I would like to be able to lean on the car and check tightness on the battery terminals without needing gloves. Perhaps a momentary test for leakage on startup?
