Old 12-28-2014, 05:04 AM   #40 (permalink)
cRiPpLe_rOoStEr
You can also consider to add some thermal insulation behind the dash, and around this metallic case you're making for the ceramic heater, in order to keep the dash more protected from that heat blast. That could eventually also make the heat irradiation more efficiently-directed thru its original HVAC ducts.
