So you plan on testing a 30/1 afr? I look forward to seeing your results. I was going to try as lean as 17/1 and go from there. My o2 won't even read past 18/1. What o2 sensor are you using? I wonder where your dcr is at 2 psi. What engine managment are you using? MS3 maybe?
