Thread: V8 fuel economy
Old 12-28-2014, 05:23 PM   #42 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by greasess View Post
So you plan on testing a 30/1 afr? I look forward to seeing your results. I was going to try as lean as 17/1 and go from there. My o2 won't even read past 18/1. What o2 sensor are you using? I wonder where your dcr is at 2 psi. What engine managment are you using? MS3 maybe?
I've been running at 30:1 for a few years now. I'm calculating anything past 21:1 A/F on mass air and fuel flow numbers. I'm running two wide-bands, a Innovate and AEM. The Innovate reads up to 21:1 the AEM reads up to 18:1.
I'm not to sure what my dcr is as of right now? My "turbo compound system" helped a ton for keeping great engine delta p numbers.
I'm running ECM Tuning for engine management.
Pressure Gradient Force
The Positive Side of the Number Line
