12-29-2014, 01:32 PM
#66 (permalink)
Originally Posted by cowmeat
So I reset my lifetime mpg a couple of weeks ago, and now I just realized it doesn't show at all.
When I hit the fcd button and switch over to where it shows the total miles, it no longer reads out the lifetime mpg. Does anybody know how to make it show again?
I think you deactivated the FCD with the FCD button. You have to hold it for a long time so it reactivate the displays. HTH
Odometer / Trip Meter / Fuel Efficiency Meter
In the center of the instrument display, below the digital speedometer display, is the combination odometer / fuel economy meter.
At the left side of this display, average fuel economy is shown. This average is updated once per minute. To the right of this average, is the odometer / trip distance display. The driver can select the lifetime odometer for the vehicle, or switch between three resettable trip meters: "Trip A", "Trip B" or "segment". The average mileage display always shows the average for the distance that is selected. That is, if trip meter A is selected, the average mileage is shown for that trip. "Segment" mode is toggled on and off by touching the FCD button. The current segment is reset by pressing and holding the FCD button while in "Segment" mode. The normal mode display can be switched between the odometer and the two trip meters by pressing the Trip button.
At the lower portion of the display, a bar graph shows the instantaneous fuel economy, which changes in real time based on the amount of fuel that the fuel injectors are currently delivering, and based on the current speed.
When the speedometer is set to mph, odometer / trip meter distances are displayed in miles, and fuel efficiency is displayed in miles per gallon. When the speedometer is set to km/h, odometer / trip meter distances are displayed in kilometers, and fuel efficiency is displayed in liters per 100km.
Both the instantaneous bar graph and the average fuel efficiency number can be turned off at the driver's discretion. To turn off the bar graph, press and hold the FCD button until the bar & legend disappear. To also turn off the numerical average, press and hold the FCD button again, until that disappears.
Trollinsight Modding Thread
2000 Honda Insight MT Silverstone Metallic #95 (CAN) 131K mi. 81.7 Lmpg
Best Tank : 100.06 MPG (US) | 120.2 MPG (Imp) | 2.35 L/100Km | 42.54 Km/L
Best commute : 130.8 MPG (US) | 157.1 MPG (Imp) | 1.8 L/100Km | 54.84 Km/L
Best Trip : 111.8 MPG (US) | 134.3 MPG (Imp) | 2.1 L/100Km | 47.53 Km/L
