Old 12-31-2014, 11:01 PM   #17 (permalink)
Cobb
Dude, you have built a few hondas. Im sure you could of easily afforded a used Insight, Prius or some over hybrid that came and went. Same stuff, different day. Once you get the car stuff figured out you just install the big box in the trunk with the batteries, converter, bms, charger and wires. Run a switch, run a power cord, run a lead to the ecu for a ready signal if available. Once you turn it on just drive and get an instant boost of mpg and extended use of EV mode if available.
Originally Posted by vrmouseyd15b View Post
That is slick! Too bad I'm too poor for a hybrid
Thanks,
Victor
