Old 01-01-2015, 04:37 PM   #17 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by naturalextraction View Post
Are you using wasted heat energy in the "heater" or exchanger or ? sorry, just saw where you are. Controlling that to maintain a delta is a bit of a btch. I use a valving system there as well.
Just seen this. I was writing a book above haha.
The waste-solvent heating has a coolant heater at the waste-solvent tank. The compressor housing is drilled and tapped with a 3/8's fitting. Then it goes to the copper tubing wrap around the inner exhaust header pipes. This then goes to the hot air valve, the waste-solvent has its own valve.
Pressure Gradient Force
The Positive Side of the Number Line
