Old 01-01-2015, 05:33 PM   #18 (permalink)
naturalextraction
naturalextraction
naturalextraction's Avatar
Im reading at restaurant and probably not absorbing this quite yet....first thing that comes to mind is perculation. I had almost exactly the same arrangements but didnt realize or measure perculation till I was already on the dyno. I was using something similar on my 72 duster. I used a similar method on my big dodge truck with 360 and figured how to control via pressure differential control devices. Had an impressive change to stability of A/F ratio on dyno testing. Amazingly consistent regardless of fuel delivery means, rpm range, load, etc.. Ill write more when im not all thumbs!
The Following User Says Thank You to naturalextraction For This Useful Post:
pgfpro (01-01-2015)
