Originally Posted by naturalextraction
Also...your efi should pull back on PW with enrichment from your solvent source or any other fuel sources. Thus you should see less gasoline consumption. I have a short video of my device converting motor oil to an easily to light blue flame....a lot of the energy is lost to adhesion as you can emagine.
So very true.
In my management system I have ability to switch to a secondary map. I'm going to have a manual switch on the hot-air control valve that will activate waste solvent enrichment secondary map.
