Originally Posted by MPaulHolmes
I'm making a new board that's going to be primarily surface mount. I found out that there are places that will populate it for like $100 per board in quantity 10 down to $17 per board in quantity 500. And surface mount parts are cheaper. ...
Paul are you going to populate the older boards for the beta test team or are you going to hold off for the revised board?
Will you be keeping the driver circuits the same and mostly making changes to take advantage of the micro controllers extra capacity?
