Old 01-04-2015, 09:45 AM   #11 (permalink)
BamZipPow
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Wink
Originally Posted by aerostealth View Post
I was looking at plastic panels at Lowes today for the under body on the F-150 and I spotted some for about $33 that were white, textured on one side and smooth on the other. I have found Chloroplast signs online (18x24 inches) but they are not big enough for my truck. The space between the frame rails needs a 4 ft by 8 ft panel to bridge it. What are some of you using for belly pan paneling? I am still going to need at least $100 in these panels not to mention fasteners. Any thoughts on this. I think my best bang for the buck is under body paneling to smooth the air flow under the vehicle.
Sounds like yer describing FRP (fiber reinforced plastic). It doesn't hold up to hard impacts very well and will fracture/snap quite easily. It's much heavier than Coroplast and can be cut with a cutting wheel/fine toothed jig saw. It will sag without support beams when used in a horizontal configuration. I built a frame from metal 2x4 studs (so I wouldn't have to drill into my frame and it would be easy to remove fer maintenance) and reinforced it with wood inserts in key spots. I used 4mm Coroplast as my final cover but I did try luan panels as my first trial material as it was inexpensive and easy to work with. I installed crossbeams as attachment points fer my belly pans.
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following User Says Thank You to BamZipPow For This Useful Post:
aerohead (01-05-2015)
