Did a little more work today.
Got some goo gone and finished cleaning up the rear bumper. Also put the H badges back on.
After that I figured I would check the valve lash and I'm glad I did. A few rocker arms we're a little loose.
Also changed the spark plugs with proper NGK's because it had Bosch Platinums in it and replaced the air filter with a fresh Wix.
That's it for now. Seems to drive pretty good now. Hopefully that will translate into better mpg's
