Originally Posted by aerostealth
I like your idea of using light steel studs as cross members between the frame as it is obvious to me my paneling material will need support. My question is how well would the 4 mm coroplast hold up by itself. Durability is an issue as is weight. Using two panels seems like less then a optimal solution.
Here's my thread on my belly pan thread with all my ups and downs along with piccies!
Under belly pan... - Toyota Nation Forum : Toyota Car and Truck Forums
I did cut down and insert 2x4 studs into my crossbeams fer better support. I think in the future I will have to setup a rubber bushing in the crossbeams to allow fer better flexing without straining the crossbeams.
You will have to provide enough support if yer gonna hang the Coroplast in a horizontal position as it will not have enough support over the 4' width.
