Old 01-05-2015, 05:13 AM   #21 (permalink)
cowmeat
cowmeat's Avatar
Princess Carriage - '20 Ford Explorer Limited
Silver - '22 Ford Maverick Hybrid XLT w/tow pkg
Maverick Hybrids
90 day: 39.54 mpg (US)
You need to already have a clutch switch or the injector kill won't work (well). IMA has to be disabled with the clutch switch or it'll keep trying to re-start.
When the clutch switch is off it won't try to re-start unless you shift into gear, making it a perfect P&G platform. Of course, when you need to charge up the IMA you have to turn the clutch switch back on. That's where I use my brake regen button, to force more juice back into the IMA battery since I rarely have the clutch switch on now. I also use my battery tender almost nightly now..
