Old 01-05-2015, 10:18 AM   #253 (permalink)
Vekke
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Lupo 3L bsfc Original map is from Dieselmotorentechnik 2000, expert Verlag book. not available on the internet. Stock lupo peak efficiency is point 205g/kwh @ 2250 rpm
The map with power curves is from from this study but it has been modified to simulate 0.8 liter 3 cylinder diesel. http://e-collection.library.ethz.ch/...h-23866-02.pdf
I have multiplied those figures so 40 kW x1,125->45 kW lines.
BSFC map should not change much at low power figures and rpm as I am not needing that much power Without a turbo the 1.2 should give about 42 hp and 84Nm when comparing to 1.9 SDI specs. The 1.9 SDI can produce 15 kW at 1500 rpm -> 1.2 (T)DI no turbo action is 9,4 Kw that is much more than I am needing at 12,25 Hp at 1670 RPM without any boost at all. 1.9 SDI can produce about 20 kW at 1700RPM so 1.2 (T)DI can produce 12,6 kW.
1.9 SDI is more efficient in steady speed driving (highway cycle) than the 1.9 TDI. Making that boost wastes diesel if you are not needing it in the first place!
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
The Following User Says Thank You to Vekke For This Useful Post:
ausias (01-06-2015)
