Old 01-05-2015, 01:28 PM   #4 (permalink)
JRMichler
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 39.65 mpg (US)
To help interpret Vekke's graph:
If you need 7.5 hp (5.6 kW) at a particular speed, the best gear ratio is that which has the engine running about 1400 RPM at that speed.
If you need 15 hp (11.2 kW) at a particular speed, the best gear ratio is that which has the engine running about 2000 RPM at that speed.
If you need 60 hp (45 kW), you don't have a choice. You only get that much power at about 4600 RPM. But if you keep the gas pedal on the floor, and change gears to get 3300 RPM, the power drops slightly to about 56 hp and the specific fuel consumption improves from about 250 to 222 g/kWh. That's 13% better (more efficient) use of the fuel.
