Thread: Outside the box
Old 01-06-2015, 03:55 PM   #9 (permalink)
oil pan 4
http://ecomodder.com/forum/showthrea...ncy-30061.html
Most of the alternators losses at least in highway driving are due to spinning it 3x crank shaft speed and only using a small fraction of the power it can produce at that speed.
Then once you remove the alternator drive you have to cut power to it because it will still draw 2 to 3 amps to power up the voltage regulator.
You can leave it powered up, it will just drain your battery that much faster.
You will find when you do an alt delete that every amp counts.
