Post 8 shows a pic of the block, I removed the grill and used caulk to stick coroplast to the inside of it for a "stealth" block. A small election sign with the grill diagonal was all that was needed in materials. Make sure to paint the material before attaching the 2 pieces. My sign was blue and yellow and from different angles you can still see it because I painted everything afterward lol.
I have not yet begun to block the lower but I am pretty sure that I can block the 2 outer sections and still get plenty of cooling using just the middle for air. When I do, I will do it from the back with black painted coroplast zip-tied to the grill. Other concerns are the fog lights, they are just open in the rear and probably causing problems for me. Thinking about using a clear film to cover the whole area and if I get enough, maybe do the lower grill that way too.
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
