Originally Posted by aerohead
Also,you may not want any type of airdam ahead of your inlet,and you'll want some radius under the bottom edge to keep the flow attached to the inlet,or you might starve the inlet.
Thanks Aero, but I think you misunderstood. I'm looking to have my dam farther BACK from the inlet. So there would be a gap of a few inches between the inlet and the dam; the dam would not be directly at the rear of the inlet. Will the dam still create cooling flow in this set-up or does it HAVE to be right behind the inlet?
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
