Old 01-07-2015, 12:57 PM   #1527 (permalink)
cts_casemod
Ideally if you plan to use an inductor, keep the output regulated.
A 144V pack can sag to very near 100V on a cold day, so keeping the output constant will help with the control loop. Or even better. Keep it off until the V/Hz ratio is reached at 25Hz or similar and then start boosting accordingly.
P-hack, what happens if you keep the same inductance value for both cases?
