Old 01-08-2015, 12:27 PM   #71 (permalink)
wdb
lurker's apprentice
PlainJane - '12 Toyota Tacoma Base 4WD Access Cab
90 day: 20.98 mpg (US)
Originally Posted by Old Mechanic View Post
I used to pull the electrical connection off the ac compressor to keep it from running in the winter.
Do you still do that? I've heard stories about AC seals and whatnot needing to see some activity over the winter months to keep from drying out. I run mine every now and then just for that reason. Usually just turn on the defrost to make the AC run. Fortunately my vehicles have a separate switch for AC, so even if it turns on when defrost is selected, I can turn it off again.
The Following User Says Thank You to wdb For This Useful Post:
Cobb (01-08-2015)
