Old 01-09-2015, 02:33 AM   #241 (permalink)
e*clipse
Permanent Apprentice
I was thinking about making some adapter rings for my back motor. If you're interested in using either a type2 CVT or Porsche 930 CVT, I could make more than 2.
Regarding axles, I'm going to get some semi-custom ones from the Driveshaft shop:
The Driveshaft Shop | Home page
They have a stock of axles, and use quality CVT's from GKN. They're not cheap, but I won't have to worry about a broken halfshaft flopping around at high speed.
For VW sand rail parts, here's a shop that sells just about every type of CV joint/axle for VW's: (I'm not sure about EMPI, to be honest....)
Rear Suspension
I did get a good recommendation for Sway-Away's axles for a good friend:
Sway-A-Way | Product List - Page 1
Combine that with some GKN CVT's and you'd have a nice reliable axle set.
- E*clipse
I was afraid that was an internal part & agree about sand rail part opportunities, but I don't have any solid leads. I have the stock VW trans mounts and will get some metal stock when I can. I'm a little hampered by circumstance at the moment.
I'm thinking ~1/8th plate with hot-rolled edges, and the rear mount will incorporate hinges for the rack and venting for the air-cooling fan.
The Following User Says Thank You to e*clipse For This Useful Post:
freebeard (01-28-2015)
