Old 01-09-2015, 03:21 AM   #17 (permalink)
AndrzejM
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
It's almost done. All i need now is to put everything under the hood. For now total cost is ~80 PLN and I doubt that it will be increased further. I used salvage parts mostly that I had in my junk.
It'll be 750W 230V heater with electric pump for circulating the coolant. Build from a heat exchanger coolant-engine oil from BMW (old Berta's engine), old electric heater and electric (12V) coolant pump from Mercedes. Pump will be used to run coolant during hot weather and EOCing.
So parts that I've used so far are:
1. Oil cooler from BMW
2. Electric heater 750W 230V
3. Electric pump 12V from MB
Pictures aren't mine - sorry.
I needed to cut out the oil cooler core and close with epoxy the oil-in and oil-out ports. Then I cut all the plastic from the electric heater, so it could fit the biggest coolant port of the coolant-oil heat exchanger. I used epoxy to glue it in again. Now i need to put it under the hood and connect electric cables and it should work. Hopefully
I'll do my best to take some pics during the installation process.
ID:	16745   Click image for larger version
ID:	16746   Click image for larger version
ID:	16747   Click image for larger version
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
The Following User Says Thank You to AndrzejM For This Useful Post:
Piwoslaw (01-09-2015)
