Old 01-09-2015, 05:56 AM   #8 (permalink)
IamIan
IamIan's Avatar
First I would say to get a comfy set of thermal underwear .. shirt top and pants to wear under your clothes ... it's the biggest 'bang for the buck'... Also a sweater or sweat shirt as a 3rd torso layer is also a good step.
Originally Posted by dirtydave View Post
I figured If I only use the space heater in the room I am in it would be cheaper but after seeing the bill I'm not so sure..
You paid $72.26 for 124 Therms of Natural Gas
You paid $74.12 for 513 kwh of electricity.
1 Therm is roughly ~29kwh of energy.
124 x 29 = 3,596 kwh of input energy
Looks like an old heating system ... Average efficiency in the 1970's was around ~65% .. Current modern systems range from 75% to 97%.
If your heating system is a bit better than the average in 1970... ~70%
3,596 x 0.70 = roughly 2,517 kwh of heat energy into the living space.
2,517 kwh of living space heat for $72.26 =
Roughly ~ $0.03 per living space kwh of heat.
Electric heater ~99% efficient.
(74.12 / 513 ) x 0.99 = roughly ~$0.14 per kwh of living space heat.
The space heater is a better fit for more targeted smaller zone heating .. but I wouldn't even consider it unless it were at least smaller than 1/5 the volume to be heated... Say a nice toasty warm bathroom for a shower , instead of trying to heat the whole living space to that same toasty warm temperature... but you leave the overall total living space at a lower temperature.
That targeted smaller volume logic is why there are also heating blankets , pads , etc ... because those also greatly reduce the total size of the space you are trying to heat , thus less total energy is needed.
Also dry air feels colder than more moist air ... even if they are both actually the same temperature.
Make sure your bubble wrap is forming an air tight seal around the windows ... it isn't enough to just put it on loosely with air gaps.
A basic infrared thermal gun (most hardware / home improvement stores) ... can also be used to look for heat leaks.
Life Long Energy Efficiency Enthusiast
2000 Honda Insight - LiFePO4 PHEV - Solar
2020 Inmotion V11 PEV ~30miles/kwh
The Following 2 Users Say Thank You to IamIan For This Useful Post:
dirtydave (01-09-2015), redpoint5 (01-09-2015)
