Old 01-09-2015, 09:13 AM   #2 (permalink)
aardvarcus
aardvarcus's Avatar
Deep Blue - '94 GMC Suburban K2500 SLE
90 day: 23.75 mpg (US)
Griffin (T4R) - '99 Toyota 4Runner SR5
90 day: 25.43 mpg (US)
Glad to have another Tacoma on here.
I put all Amsoil fluids in my 2005 Tacoma, except for motor oil I use Mobil 1 as it is more convenient to purchase that locally. Amsoil has multiple fluids of identical weights, so you need to be sure you purchase the correct fluid of that weight. Make sure you correctly use GL-4 or GL-5, which ever your Tacoma needs. Wrong fluid have the potential to eat syncros or cause excessive force to shift.
Do you know what gearing you have, and how many RPMs are you turning at your normal driving speeds?
With a 96, factory would have sealed beam headlights, so you can always convert them to LED, as there are DOT approved sealed beam LED replacements with good optics available from major manufacturers. (Not ebay drop in blind everyone junk.) Add some lexan covers over the headlight recesses and you would be set.
The Following User Says Thank You to aardvarcus For This Useful Post:
Joggernot (01-10-2015)
