I have thought of that.
I actually lose less than that at idle, about 0.6 l/hr (when warm!) but no matter.
The engine will already harvest some of the heat by its EGR system.
But others have done that already.
I want to know just whether an electric WAI does actually do anything.
If it does then we can get compare the merits to other WAI systems.
I only need WAI in the first minutes. Once warm my grill block does enough for a healthy intake temp. Whatever I use as WAI needs to be switchable, light and cheap.
I would like to try the hot water method as an experiment. I just need to find some way to transfer its heat to the intake air. Suggestions are welcome
I think I have a metal tablet tube which I can fill with hot water & shove in the intake snorkel. My UG should reveal whether it really helps intake temp...
I hope I can find it. At least it is a very simple experiment.
