Before I had the carpet yanked out from under me financially I was going to buy a used electric golf cart and use the parts to drive the front axle of a 4wd vehicle like a suzuki sidekick. I would get a stick shift model and remove the transfer case or disable it. I would then have a small battery bank in the rear and use the gas to get up to speed, then setup a FAS, shift to neutral and flip on the speed controller for the electric motor connected to the front axle.
