Old 01-12-2015, 01:06 PM   #1573 (permalink)
P-hack
P-hack's Avatar
awesomer - '04 Toyota prius
Originally Posted by cts_casemod View Post
For 100Khz it would be AWG26 or 0.40mm, 41 strands. At this point makes sense to get the litz wire, doing it manually would yield a very large diameter conductor.
Recalculating it is more like 168 strands of 26awg magnet wire for ~70A, 4awg equivilant, litz or twisted. Twisting copper wire is actually how you straighten it, so without the braiding it should actually be a bit narrower. unless you use a untwisted braid. Just hoping to avoid more sourcing headaches than necessary.
