Old 01-13-2015, 04:43 AM   #7 (permalink)
niky
Pretty much echoes my own testing. Longer piping, up to a point, helps make more power... which helps explain why CAIs are effective in making power. I ended up with a long stainless tube attached to my intake, putting the filter as far away from the engine as possible, but still inside the engine bay, up and away from possible water ingestion.
My tube made 5 hp more with the K&N filter than a standard legth tube with the same filter, and up to 10 hp more with extra fuel and ignition tuning. Certainly bang for the buck.
Unfortunately, finding the proper length and diameter for your car is an expensive endeavor, unless someone else has already done the legwork for you.
