fyi, @paul, if you change vIn to 48v and the load to 2.3 ohm, you should get about 161v out @ 70A (still 72% DC), which should look pretty much the same to the inductor (and is a saner first test).
@cts, the ch is rated @ 120uh, if it can handle the overcurrent.
